![]() | Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2648 ![]() ![]() |
ACC with queue assist / stop-and-go is now operational after successfully initiating radar unit calibration using a new iidTool option developed because I needed it and presumably others may also need it, then happening to drive between 2 sets of tall metal gate-posts at the local tip which caused the flashing radar icon to go off. An engine restart after locking then unlocking the vehicle activated ACC. No adverse effects occurred in today's mix of fast and slow, single and multi lane traffic and on-coming vehicles.
Niklas Member Since: 18 May 2018 Location: Zürich Posts: 2 ![]() ![]() ![]() |
Dear GraemeS,
Queue Assist is software only so can be enabled. The caution from some UK people is that as queue assist wasn't available on the L322, the software may not have been finalised so may not work properly. However the couple of times that I tested queue assist it did slow the car to a stop and in good time. I wondered if following slow vehicles might not be as smooth as it needs to be as slowing then accelerating seemed to be reacting too quickly but that was in excess of 40 kph anyway, not under 20 kph.
A very big thank you for your swift reply!
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
So, I have just found this thread and wonder if I got it right?
The required hardware when retrofitting ACC to the 4.4 TDV8 are the radar unit, its bracket, the short wire harness to connect the radar unit to the main harness connector below the right headlight and the switch bank. ACC support already exists in the 4.4's ECM but the CCF needs to be changed to show that ACC is fitted. Note that the radar unit is physically the same as fitted to various vehicles but the software must be for the MY10-12 L322 or MY10-13 RRS. The used radar unit that I purchased was incorrectly advertised as the correct LR part number but it was not, instead for a Jag so the s/w had to be re-flashed. |
Thanks Graeme, great.
The radar unit does have a flat face but don't buy one that just looks the same.
just to recap again - this is the slim vs fat type sensor, and we are talking slim? They seem to be sold under the same number as you can find both variants with LRO29157 Thanks again, heppsen 2017 MB V-Class 2016 Q7 (gone) 2012 FFRR TDV8 2012 Smart Pulse Turbo 1986 MB W126 1965 LR Series 2A 1961 LR Series 2 |
This link https://www.ebay.ie/itm/JAGUAR-LAND-ROVER-...3d65ff8982 is to one that appears to have the correct assembly number BH32-9G768-AD on the label, if I can read it correctly. As I discovered, some sellers advertise other versions as the correct LR part number when they are not, noting that the LR number is not on the label anywhere. Mine has CX23-9G768-AD on the label which is for a Jag so had to be reflashed with the correct software.
Nick Evans Member Since: 10 Dec 2013 Location: Dorset Posts: 10 ![]() ![]() |
Graeme,
Screenshots from my IIDTool display screen as the parameters didn't quite fit on 1 screen.
Thanks Graeme,
parts ordered (wiring and bracket) at the dealer new and switch bracket fro steering wheel and sensor through the bay. We will see - the sensor was even advertised as new. I will report back.
