Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help
Page 2 of 15 <123 ... 131415>
GraemeS
Australia
Thanks Colin, your retrofit was the prime mover in my quest to retrofit ACC to my L322.
For the 4.4 the radar unit LR029157 (get the correct the assembly number posted above if buying used), bracket LR022947, short wiring harness LR023028 to connect the radar unit to an existing wiring harness socket and left steering wheel switch pack LR029644 are required. The radar unit is located behind the right end of the bumper. The switch packs changed from earlier versions so a new right one might also be required to match. The 5.0 uses a separate ACC ecu, an additional radar unit and a link cable between the 2.
Post #433033 28th Mar 2017 8:54pm
GraemeS
Australia
ACC retrofit completed
ACC with queue assist / stop-and-go is now operational after successfully initiating radar unit calibration using a new iidTool option developed because I needed it and presumably others may also need it, then happening to drive between 2 sets of tall metal gate-posts at the local tip which caused the flashing radar icon to go off. An engine restart after locking then unlocking the vehicle activated ACC. No adverse effects occurred in today's mix of fast and slow, single and multi lane traffic and on-coming vehicles.
An unexpected benefit it that the gearbox now downshifts on hills when it should where previously it would stay in top gear until revs dropped to around 1,000 rpm by which time the speed had dropped significantly so would drop several gears.
Post #439324 23rd May 2017 12:04pm
Niklas
Switzerland 2012 Range Rover Autobiography TDV8 Santorini Black
Dear GraemeS,
I have read this thread with interest as I have very recently bought a 2012 Range Rover with ACC. After some driving with it I realise that the car’s ACC “lets go” at about 20km/h, and some internet searching led me to a couple of forums, all of which you frequently contributed to.
I see that you have successfully retrofitted a system that allows “stop and go” about a year ago and so I thought I should try to ask you some specific questions regarding my system, I hope you do not mind.
Was the “Queue assist” an optional extra on the 2012 Range Rover Vogue Autobiography? If so, is it just a matter of enabling the JAG option with an IID tool to get this option or would this require additional hardware?
Thank you in advance for your reply.
Post #478752 18th May 2018 8:08am
GraemeS
Australia
Queue Assist is software only so can be enabled. The caution from some UK people is that as queue assist wasn't available on the L322, the software may not have been finalised so may not work properly. However the couple of times that I tested queue assist it did slow the car to a stop and in good time. I wondered if following slow vehicles might not be as smooth as it needs to be as slowing then accelerating seemed to be reacting too quickly but that was in excess of 40 kph anyway, not under 20 kph.
Forward Alert isn't appreciated by my wife as a passenger as every time it has triggered I have been aware of the situation but I leave it enabled anyway.
Post #478764 18th May 2018 10:20am
Niklas
A very big thank you for your swift reply!
That right there justifies be 400 odd euros that the GAP diagnostic Bluetooth tool costs, and who knows what else there might be to add??
I shall test the new settings with caution whenever I get around to set them and once I have taken delivery of the OBD bluetooth tool from GAP, then I will share my own experiences with it.
Post #478766 18th May 2018 10:57am
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
So, I have just found this thread and wonder if I got it right?
You can buy a radar second hand from ebay, get the bracket from your dealer, fix it in the cars front, buy the ACC module and plug it into the - hopefully existing yellow plug behind the kick panel and fix the module there, then update the cars software by switching the options of ACC to „on“ in the control module and change the left hand button cluster on the steering wheel and then have ACC retrofitted to m 2012 TDV8?
Thats one of the things I am missing in my vehicle. It has the 1200W HD Hifi, the camera system, the light pack, tow hook, cooled and heated seats and now recieved the power steps, but I am really missing the ACC sStem.
Can you update the software at the dealer or do you need a IID tool from GAP?
Thanks and regards
Heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #479422 26th May 2018 6:55pm
GraemeS
Australia
The required hardware when retrofitting ACC to the 4.4 TDV8 are the radar unit, its bracket, the short wire harness to connect the radar unit to the main harness connector below the right headlight and the switch bank. ACC support already exists in the 4.4's ECM but the CCF needs to be changed to show that ACC is fitted. Note that the radar unit is physically the same as fitted to various vehicles but the software must be for the MY10-12 L322 or MY10-13 RRS. The used radar unit that I purchased was incorrectly advertised as the correct LR part number but it was not, instead for a Jag so the s/w had to be re-flashed.
Post #479442 26th May 2018 9:54pm
heppsen
Thanks Graeme, great.
Thats one thing that will be done soon then.
Am I right in assuming the 2012 TDV8 FF should have the flat type radar sensor?
How can you re flash the radar?
Thanks again
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #479456 27th May 2018 5:47am
GraemeS
Australia
The radar unit does have a flat face but don't buy one that just looks the same.
Gap Diagnostics provided the L322 s/w to flash over the Jag s/w.
Post #479467 27th May 2018 9:54am
heppsen
just to recap again - this is the slim vs fat type sensor, and we are talking slim?
They seem to be sold under the same number as you can find both variants with LRO29157
Thanks again,
heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #480167 5th Jun 2018 6:22am
GraemeS
Australia
This link https://www.ebay.ie/itm/JAGUAR-LAND-ROVER-...3d65ff8982 is to one that appears to have the correct assembly number BH32-9G768-AD on the label, if I can read it correctly. As I discovered, some sellers advertise other versions as the correct LR part number when they are not, noting that the LR number is not on the label anywhere. Mine has CX23-9G768-AD on the label which is for a Jag so had to be reflashed with the correct software.
This is the same item. https://www.ebay.de/p/Jaguar-Land-Rover-Fr...6007494571
The picture on this link http://www.2040-parts.com/jaguar-land-rang...-i1350327/ shows the bracket and short link harness but the radar unit isn't visible.
Post #480177 5th Jun 2018 9:55am
Nick Evans
Graeme,
can you list the changes you made to your vehicles ccf with your iid tool please ?
Post #480727 11th Jun 2018 9:47pm
GraemeS
Australia
Screenshots from my IIDTool display screen as the parameters didn't quite fit on 1 screen.
Post #480751 12th Jun 2018 10:28am
Nick Evans
Thanks Graeme,
I’ve ordered all the bits, can’t wait to give it a try !
Post #480760 12th Jun 2018 12:28pm
heppsen
parts ordered (wiring and bracket) at the dealer new and switch bracket fro steering wheel and sensor through the bay. We will see - the sensor was even advertised as new. I will report back.
thanks for all your help and infos
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #480902 14th Jun 2018 4:00pm
