Home > Technical (L322) > 4.4 TDV8 sounds like wastegate chatter....
gg2201
Hi all some advice been looking at so many TDV8s and finally found a very tidy example but when I took it on a test drive the only thing that was noticeable was what almost sounded like waste gate chatter on slight acceleration/changing up.
I've searched to see some others have had this also but no actual answer to what it is or is it something to be worried about.
Annoyingly aside from the leaky O-rings I spotted also it was very well looked after example. I've put a holding deposit down but can change my mind if needed.
Post #477603 6th May 2018 9:02am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
No noises from mine like that, be wary. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #477607 6th May 2018 9:38am
GGDR
what the hell is waste gate chatter ?
. Cheers, Greg
Post #477609 6th May 2018 10:10am
dolph34
It's when a Watergate makes a chattering noise Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #477610 6th May 2018 10:24am
GraemeS
Australia
At the right part-throttle opening and revs, changing up on mine can cause the secondary inlet isolation valve to flutter as revs drop below the rpm threshold for the valve to be open when it was open in the lower gear. It most often occurs when easing off the throttle after getting the revs up a little to get off the mark. Holding the throttle open to get the revs higher before easing off avoids the flutter, as does manually up-shifting before the engine gets anywhere near 2000 rpm.
Post #477611 6th May 2018 10:33am
dolph34
Should the Watergate be dampened in some way ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #477612 6th May 2018 10:35am
mpirie
Investigated for sure Whistle
Mike
Post #477616 6th May 2018 11:06am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
What people call “wastegate chatter” is actually the noise of the air in the inlet tract going back into the turbo compressor when the throttle plate is closed. It’s the reason OEM stuff has recirculating bypass valves, to stop the noise and to protect the turbo bearings.
Post #477621 6th May 2018 12:56pm
gg2201
It was coming from the OS of the engine could hear it inside the car and also if you revved it quite hard stationary through the air box on that side also, obviously noise only happens when you close the throttle so to speak.
I've seen others have had the actuators replaced which cured for a while then the noise returned
If it was a modified "RICE" car I wouldn't have taken notice but sounds odd on a RR. It wasn't ridiculously loud but enough to think what is that.
Post #477622 6th May 2018 1:29pm
Paul thornton
Test drive another one and see if it does the same is the obvious answer.
The td6's have a kind of dump valve whistle when backing off the revs. Some people notice it others don't.
Post #477633 6th May 2018 3:52pm
All owners of 4,4tdv8's can provoke this noise by reversing up a steep gradient and open the throttle heavily... Equally you can apply a bit of left foot braking and heavy throttle input... Worth experiencing this phenomenon before it catches you out one day... Can sound quite worrying if your not expecting it... Thumbs Up
Post #477682 7th May 2018 4:38pm
counter of beans
England 2012 Range Rover Vogue TDV8 Santorini Black
Craig, is this "chatter" a problem; I mean, does it damage the engine in any way? Or is it just a "they all do that Sir" and we shouldn't worry about it?
Post #477884 9th May 2018 10:40pm
