![]() | Home > Technical (L322) > 4.4 TDV8 sounds like wastegate chatter.... |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
No noises from mine like that, be wary. 2015 4.4 AB
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
what the hell is waste gate chatter ?
It's when a Watergate makes a chattering noise |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2651 ![]() ![]() |
At the right part-throttle opening and revs, changing up on mine can cause the secondary inlet isolation valve to flutter as revs drop below the rpm threshold for the valve to be open when it was open in the lower gear. It most often occurs when easing off the throttle after getting the revs up a little to get off the mark. Holding the throttle open to get the revs higher before easing off avoids the flutter, as does manually up-shifting before the engine gets anywhere near 2000 rpm. |
Should the Watergate be dampened in some way ? 2015 4.4 AB
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 908 ![]() ![]() ![]() |
Investigated for sure |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
What people call “wastegate chatter” is actually the noise of the air in the inlet tract going back into the turbo compressor when the throttle plate is closed. It’s the reason OEM stuff has recirculating bypass valves, to stop the noise and to protect the turbo bearings. |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 ![]() ![]() ![]() |
It was coming from the OS of the engine could hear it inside the car and also if you revved it quite hard stationary through the air box on that side also, obviously noise only happens when you close the throttle so to speak.
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Test drive another one and see if it does the same is the obvious answer.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
All owners of 4,4tdv8's can provoke this noise by reversing up a steep gradient and open the throttle heavily... Equally you can apply a bit of left foot braking and heavy throttle input... Worth experiencing this phenomenon before it catches you out one day... Can sound quite worrying if your not expecting it... |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 ![]() ![]() ![]() |
Craig, is this "chatter" a problem; I mean, does it damage the engine in any way? Or is it just a "they all do that Sir" and we shouldn't worry about it? |
