Home > Technical (L322) > 4.4 V6 key problem
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
4.4 V6 key problem
Hi guys , car started making strange stepper motor type noises from the key area, so rather stupidly I sprayed some lubricant into where the key goes and now whereas it was fine before it now is almost solid and you have to turn ans wiggle the key to start it, it feels really solid when trying to turn the key. Any ideas? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #477175 30th Apr 2018 9:18am
this from the wiki might help,
http://www.fullfatrr.com/forum/topic40178.html
http://www.fullfatrr.com/wiki/Key_stuck_in_ignition ... - .- -.
Post #477182 30th Apr 2018 9:53am
JohnnyDangerous
Thanks Stan, it was fine until I put WD40 in the lock Big Cry One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #477236 30th Apr 2018 9:00pm
Motobox
United Kingdom 2004 Range Rover Vogue Td6 Galway Green
Life! I sprayed degreaser on the lower tailgate, as it wouldn't latch up. At first it was job done. Then the solid gunk must have reanimated into gunge. Now it's stuck shut. Another job FFS!
Post #477255 1st May 2018 9:25am
roblane65
just for reference ,you should never use any type of wet lube on a key cylinder, lock or locking mechanism. Dry powder grafite from a locksmiths or good hardware shop usually does the job Thumbs Up Range rover 4.2 SC 06MY.
Post #477306 1st May 2018 7:59pm
