![]() | Home > Technical (L322) > Start Button not responding |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 386 ![]() ![]() |
Does the TFT screen show the image when you open a door?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35663 ![]() ![]() |
if you have all electrics working then it could be the starter motor...keep pressing the button hopefully it will fire up.. ... - .- -.
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
The TFT brings up Range Rover icon and nothing on the cluster.. just the mileage and date. Current:
It not bringing up the other light one the cluster that you would normally get when the ignition is on the ON position. Looks like another gremlin unless someone experience the same issue and knows a solution. I have read on various posts that folk have left the motor locked for few hours and been fine after that. Trouble is I am outside the school and csnt leave the car here.. Going to disconnect the battery and see if it helps Current: - L560 Velar HSE R-Dynamic D180 - Peugeot 508 2011 - 2.2 HDi GT Past: - FFRR V 2010 - 3.6 TDV8 - Citroen C4 1.6i Petrol - Mitsubishi Shogun 3.2 DID - Peugeot 607 2.2 HDi - Nissan Primera 1.8 SVE - Honda Civic 1.6 VTEC |
good plan...consider a flat/faulty battery as well... ... - .- -.
was just going to say "think flat battery".
Yes lock and unlock fine.. now getting "Low Battery - Start the Engine".. so may be battery related..
Hope they get to you quickly and it's something simple. __
I hope so.. fingers crossed Current:
$loody Gremlins.. wish I had my 10mm key !!
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
Glad you got it going |
the battery low error probably was a result of you constantly trying to start the FF..i reckon its the starter motor.. ... - .- -.
Kgeddes.. the 10mm key is a forever running joke which is you never find one when you need one. If I had one in the car.. I would have reset the battery myself and would have been on the go rather than waiting for AA.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Could one of the battery terminal connection have been loose which was solved when he did the reset and tightened it back up? Current Fleet:-
