![]() | Home > Maintenance & Mods (L322) > Tow bar |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
if its a westflia then the exhaust hangers are different.. ... - .- -.
pip1977 Member Since: 13 Jul 2015 Location: Northants Posts: 16 ![]() ![]() ![]() |
Hi Stan it’s a brink towbar that’s fitted and thanks for moving post to right place 2004 td6 Zambezi silver
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Exhaust hangers moved on later cars but if your able then they can be modded |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 ![]() ![]() ![]() |
Sorry for the hijack but did Land Rover make more than one type of tow bar for the l322 just mine has what looks like a heavy duty fixed one but it has a combination hitch with a Land Rover plate on it |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 228 ![]() ![]() ![]() |
The official tow bar is made by Westfalia, you can fit it with either a quick release to ball, or what is commonly know as the farmers hitch which allows you to bolt a regular tow bal at different heights. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Pictures would help ![]() However, as above, sounds like you have the 'farmers hitch' or drop plate tow bar - if so, it bolts into a 50mm square receiver - and there is another detachable option. Does it look like this - ![]() |
This is what’s fitted
So your's is an aftermarket unit made by Witter - and not the 'official' LR one made by Westfalia - there are other manufacturers who make a tow bar that fits a RR also. |
Billaboard Member Since: 03 Aug 2017 Location: Wirral Posts: 74 ![]() ![]() ![]() |
The original question was about a hitch from 2004 FFRR like mine.
I have seen adjustable hitch mountings fitted to farmers hitch, I think miggit did it and I am pretty sure Sam (L19MUD) did something similar when he borrows my farmers hitch last year. |
Thanks, Jamie. All I have to do now is save up for it! Old 110 2.3 Petrol ???? - ????
