Home > Maintenance & Mods (L322) > Tow bar
pip1977
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Tow bar
Hi will a tow bar from a 2004 fit onto a 2011 model? Looking at upgrading car and being tight want to swap over if the new car I find doesn’t have one. Thanks Smile 2004 td6 Zambezi silver
2006 fiat scudo van
1971 1300 vw beetle
Post #476666 24th Apr 2018 7:10pm
if its a westflia then the exhaust hangers are different.. ... - .- -.
Post #476673 24th Apr 2018 7:55pm
pip1977
Hi Stan it’s a brink towbar that’s fitted and thanks for moving post to right place 2004 td6 Zambezi silver
2006 fiat scudo van
1971 1300 vw beetle
Post #476675 24th Apr 2018 8:23pm
Exhaust hangers moved on later cars but if your able then they can be modded Thumbs Up
Post #476689 24th Apr 2018 10:47pm
Steveo
Sorry for the hijack but did Land Rover make more than one type of tow bar for the l322 just mine has what looks like a heavy duty fixed one but it has a combination hitch with a Land Rover plate on it Neutral
Post #476743 25th Apr 2018 9:11pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
The official tow bar is made by Westfalia, you can fit it with either a quick release to ball, or what is commonly know as the farmers hitch which allows you to bolt a regular tow bal at different heights.
Post #476744 25th Apr 2018 9:34pm
Pictures would help Whistle
However, as above, sounds like you have the 'farmers hitch' or drop plate tow bar - if so, it bolts into a 50mm square receiver - and there is another detachable option.
Does it look like this -
Post #476747 25th Apr 2018 9:51pm
Steveo
This is what’s fitted
Post #476765 26th Apr 2018 6:57am
So your's is an aftermarket unit made by Witter - and not the 'official' LR one made by Westfalia - there are other manufacturers who make a tow bar that fits a RR also.
Post #476770 26th Apr 2018 7:54am
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
The original question was about a hitch from 2004 FFRR like mine.
Mine came with the original removable hitch, which I have been hoping to change to the farmers hitch. On this I was hoping to fit the heavy pin-adjustable height towball assembly that came originally from one of my old 110's.
In Alistair's excellent photo of his farmer's tow hitch, the towball mounting seems far too far back to be able to mount my very industrial and quite large towball assembly.
His is a later vehicle, so my question is whether, on a 2004 vehicle, the hitch plate protrudes far enough to be clear of the back bumper? Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #476821 26th Apr 2018 3:49pm
Jamiehol
I have seen adjustable hitch mountings fitted to farmers hitch, I think miggit did it and I am pretty sure Sam (L19MUD) did something similar when he borrows my farmers hitch last year.
Post #476823 26th Apr 2018 4:29pm
Billaboard
Thanks, Jamie. All I have to do now is save up for it! Old 110 2.3 Petrol ???? - ????
Post #476827 26th Apr 2018 4:54pm
