![]() | Home > Technical (L322) > Gutless TD6 |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Injectors? try a leak test. .
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 ![]() ![]() ![]() |
In my experience, much more likely to be leaking intercooler pipes or, perhaps, a leaking intercooler.
Batpooh Member Since: 28 Jan 2014 Location: Aylesbury Posts: 13 ![]() ![]() ![]() |
Its running to well to be injectors i feel, whatever it is its effecting all the injectors at once hence my thoughts on high pressure pump, but there seems to be no way to test the pressure? |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
If you have an IID tool you can check the pressures of both the High Pressure and Low Pressure pumps. May be worthwhile seeing if anyone local to you has an IID and get the VIN code for your vehicle to check. |
I believe IID tool is capable of reporting live rail pressures. Other diag tools may too.
i shall check out the hose's thanks for the reply |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
Are you sure its not just normal as they are a bit gutless anyway!
Cheers i shall do some more checks on the hose etc and will report back |
@ Paul Thornton
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 806 ![]() ![]() ![]() |
Batpooh, I am having a similar issue at the moment but thankfully its intermittent and if I drive carefully there seems to be no issue. I have checked Low and high fuel pressures, turbo actuator and boost, vac and turbo hoses, live injector values and all look good. Tested continuity of loom all good. The car feels as though it's running out of fuel under prolonged heavy load. It is then gutless like yours but after a period of sitting ticking over becomes good again. I am going to change the in tank and external low-pressure fuel pumps as they are very cheap. Under order, they should be here soon and I will report back once fitted.
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
I bought an injecotor loom form Land rover Oz for about $90 last year, the UK was nearly $300.! |
I picked up a new loom for A$150 inc tax and shipping from an Australian supplier, they had to make a special order. My issue was solved by changing both electric fuel pumps but I wanted to swap the loom as a precaution as I am planning a very long outback trip in Sept. Changing the pumps has transformed the performance and the fuel consumption seems to have improved too. 2007 TDV8 VSE
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Check the small vacuum pipes for leaks, especially from the valve attached to the drivers side, engine compartment,inner wing.
Hi Peoples |
