Thinking of fitting a power boosting chip thingy? | |
Possibly not the most rigorous test of the Torquing Diesel CRD Digital Delphi but thought you might be interested.
Relatively easy to fit as you 'simply' plug it into the existing wiring*.
Improves performance slightly**.
Improves fuel economy slightly***.
*You have to undo the two bolts that hold the air box/ valance thing at the back of the engine bay and pull that out. Once you have done that you can reach down the back of the engine and reach the wire you need to unplug and plug into the unit. The unit itself can then be threaded into relative safety out of the main engine bay and into the boxed off area in the top left.
** For me 0 - 70mph dropped from 9.9 to 9.5
*** The same 20 mile route with a mix of A road, B road and Motorway driving gently and smoothly average mpg went from 27.3mpg to 28.5mpg
ALL SPEED TESTS WERE ON A CLOSED PRIVATE ROAD
