Home > In Car Electronics (L322) > Rear auxiliary input 3.5mm
jimoc
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
Can you hear music on the car speaker if you plug a device into the 3.5mm jack on the AVIO panel connected to the rear entertainment system ?
Post #476104 17th Apr 2018 8:14pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Yes if you select Aux on the touchscreen 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #476105 17th Apr 2018 8:21pm
jimoc
Thanks for your reply, I thought that would be the case, but I don’t seem to get any sound from mine
Post #476106 17th Apr 2018 8:22pm
nino_nino
I use amplifier when playing music from my phone. aux is not very sensitive.
Post #476140 18th Apr 2018 2:23pm
jimoc
How do you connect to the Logic7 amp for your phone ?
Post #476173 18th Apr 2018 9:31pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I think he means he puts an amplifier between phone output and aux input. I did this on my D3 though it was a permanent install tapped into the Aux circuit in the passenger footwell with the amplifier in the glovebox. The Aux input needs a high output device to drive it, hence the amplifie. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #476174 18th Apr 2018 9:51pm
jimoc
Thanks, that makes sense as currently I can’t get any output from the AUX plugged directly to my IPhone
Post #476180 19th Apr 2018 6:55am
nino_nino
jimock, when you plug in Iphone do you crank volume up, you my try plugin in just the cable, select 'aux '
start engine and listen for static nose. this will tell you if aux is working or not. if you hear static than aux is working.
Nino,
Post #476181 19th Apr 2018 7:37am
jimoc
Thanks I will try this stactic test to ensure the AUX is working
Post #476182 19th Apr 2018 7:39am
