![]() | Home > In Car Electronics (L322) > Rear auxiliary input 3.5mm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 333 ![]() ![]() ![]() |
Yes if you select Aux on the touchscreen 4.2 SC - sold , now bought back
jimoc Member Since: 01 Mar 2018 Location: Edinburgh Posts: 16 ![]() ![]() ![]() |
Thanks for your reply, I thought that would be the case, but I don’t seem to get any sound from mine |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
How do you connect to the Logic7 amp for your phone ? |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 521 ![]() ![]() ![]() |
I think he means he puts an amplifier between phone output and aux input. I did this on my D3 though it was a permanent install tapped into the Aux circuit in the passenger footwell with the amplifier in the glovebox. The Aux input needs a high output device to drive it, hence the amplifie. 2016 Skoda Octavia VRS Estate
Thanks, that makes sense as currently I can’t get any output from the AUX plugged directly to my IPhone |
Thanks I will try this stactic test to ensure the AUX is working |
