Home > In Car Electronics (L322) > Strange CD Player problem
Discotigger
My CD Player (Clarior 6CD Unit) recently stopped working, in that it wouldn't load the CDs but just came up with 'Invalid Disc'. Gave the unit a bash, as suggested in other posts and it worked for a short while, before going belly up again.
Gave the unit a blast out with compressed air and it now loads all the CDs. However, it will now only play the first 1 minute of the first song and then stops, does this on all the CDs.
Have I possibly got something jammed in the drive, or is there a belt that has come off and is stopping the head from moving across the CD?
Has anybody taken the Clarion Unit apart and has any information or even photos to shed any light on the matter. Don't want to remove the dash unnecessarily, just to discover the CD Unit is FUBAR and needs replacing, but if repairable would be happy to do that.
Post #476093 17th Apr 2018 7:26pm
Bluespanner
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
Bit of a resurrection I know, but I have the same problem, did anyone get to the bottom of this?
Post #578575 5th Jan 2021 7:48pm
Gsxr1250dave
Remove the CD player strip down and clean the laser
Post #578596 5th Jan 2021 10:13pm
Discotigger
I started stripping down the dash to get the CD player out, but turned out to be a PITA. Gave up in the end and just got an FM radio emulator and ipod for my music. Replaced my fattie last year with a newer 4.4 TDV8 so didn't bother with the old cd player in the end.
As mentioned, the FM radio emulator/ipod may be an easier option, but if you want to strip down the CD player, you need to remove the dash top and a few other bits to get access. Then it's a case of trying to repair the old CD player or just getting a second hand (working) replacement unit.
@Bluespanner, just noticed you have a 2012 Vogue SE, so you may be better off using the USB or aux/ipod connection in the Centre Console cubby to plug in an ipod or similar device for your music. Thumbs Up
Post #578608 6th Jan 2021 12:23am
danielb
Hi there, I repair these cd changers and stock all the parts needed to fix these units, turnaround time is normally a couple of days.
Just let me know if you want yours repaired.
I also repair the 6 disc dvd changers.
Many thanks Daniel.
Post #579363 11th Jan 2021 7:28pm
Sonearly
Will endorse danielb. Sent mine to him with same issue as yours and came back fixed and no issues since
Post #579667 13th Jan 2021 9:54pm
Alan Gerecke
United States 2008 Range Rover HSE 4.4 V8 Stornoway Grey
Many thanks Daniel.
I live in the USA can I send you my CD player its from a 2008 HSE? Alan Gerecke
Post #607953 2nd Oct 2021 4:50pm
Alan Gerecke
It isfar to complex for me to fool with
Post #609325 15th Oct 2021 7:53pm
Ikam
Canada 2008 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Cd changer
I have replaced my cd changer twice now invalid disc issue.
It first began with original player would stop playing slightly after a minute into song.
The last unit I purchased used I put in and started playing but it too stopped playing a minute into a song. Now it just reads invalid disc. Right back where I started! Any chance it’s another part of the entertainment system? Or do I just keep getting bad cd changers?
Post #632344 20th May 2022 1:29pm
Discotigger
Ikam, I doubt it'll be anything other than the CD player at fault. If you still have the original unit you took out I'd see if anyone local to you can strip down and possibly repair it, then you know you have a good player.
EDIT: we have a guy here in the UK who can repair these units, so there's a good possibility there'll be someone in Canada who can do the same. Any audio / hi-fi repair shop should be able to help out.
Post #632351 20th May 2022 2:40pm
