Home > Technical (L322) > Not turning over |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
ok update ! A simple hammer resoved my problem , cant believe it after all the time spent on electronics console off etc. I f only it clicked when I turned the key it might have given me a clue straight away.
9th Apr 2018 12:30pm |
I got a s/h starter delivered and wasn't in a great state , so I stripped mine down which internally was in better condition . The real reason was the original body had a snapped bolt in it on the main body, I snapped it it had welded itself in with corrosion over the years, so removing the body from the s/h one was the solution . Rebuilt the internals cleaning them out first and lightly , very lightly dabbing with lithium grease in the plastic planetary gears and moving mechanical s , fitted it back on and the difference was amazing , a lot quicker turn over and smoother. Very PLEASED , JUST AN OPTION IF SOMEONE ELSE HAS THE SAME PROBLEM AS MYSELF. |
13th Apr 2018 10:21am |
