Home > In Car Electronics (L322) > Reverse Camera upgrade help needed please
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys I know theres a few threads with this topic but I'm struggling on the new camera I have there is a black and yellow wire coming from the yellow phono lead which I cut off where do these wires go to? Also there are the black and red leads do these connect to the power source if so which wires go where? Is it the red from camera to red/orange on car and black from camera to the brown on car. Also is it possible to blow a fuse to the reverse camera if so which fuse is this please any ideas?
Cheers
Jay
 Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #475498 11th Apr 2018 5:45pm
join the two blacks together ..the red is positive and the yellow is the video feed... ... - .- -.
Post #475501 11th Apr 2018 6:13pm
jaysta10k
Hi Stan so the two blacks from the new camera you mean join them together? The red positive goes to the red feed in the car and the yellow wire goes to the video lead in car. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #475506 11th Apr 2018 6:25pm
that's correct.. ... - .- -.
Post #475512 11th Apr 2018 7:04pm
jaysta10k
yep tried that still got black screen of death I will buy another camera as maybe this one isn't working also is there anyway I have blown any fuse to the camera when trying to connect if so which fuse please?
Cheers
j Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #475519 11th Apr 2018 8:27pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
The black wire with the yellow goes to the braided earth on the coax.
Use the original camera coax connector.
Cut it about 6" from the connector and strip it back.
Solder Yellow wire to centre wire and twist the braided shield together and solder to the black wire.
As you said the red goes to the red/yellow live feed and the black to the brown.
I did this job yesterday and all worked fine. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #475523 11th Apr 2018 9:22pm
jaysta10k
confused here as Stan says match up the two black wires on the replacement camera together? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #475528 11th Apr 2018 9:41pm
Grofus
I installed the same camera and wired it as I described. It works very well.
By joining the ground wires together you risk introducing interference as the ffrr uses lots of modules and electronics.
Wire the video side separately and I think your problem will be solved 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #475530 11th Apr 2018 9:55pm
go with grofus suggestion..mine works for cctv wiring and i've not taken into account of the FF's wiring.. ... - .- -.
Post #475531 11th Apr 2018 9:55pm
jaysta10k
ok will do
cheers Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #475534 11th Apr 2018 10:36pm
