![]() | Home > In Car Electronics (L322) > Reverse Camera upgrade help needed please |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
join the two blacks together ..the red is positive and the yellow is the video feed... ... - .- -.
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
Hi Stan so the two blacks from the new camera you mean join them together? The red positive goes to the red feed in the car and the yellow wire goes to the video lead in car. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
that's correct.. ... - .- -.
yep tried that still got black screen of death I will buy another camera as maybe this one isn't working also is there anyway I have blown any fuse to the camera when trying to connect if so which fuse please?
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
The black wire with the yellow goes to the braided earth on the coax.
confused here as Stan says match up the two black wires on the replacement camera together? Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
I installed the same camera and wired it as I described. It works very well.
go with grofus suggestion..mine works for cctv wiring and i've not taken into account of the FF's wiring.. ... - .- -.
ok will do
