Home > Maintenance & Mods (L322) > Paranoid about the heat in one my new disks (rotas)
Webbie
So, I have new rear callipers, disks & pads fitted. The calliper carriers were not changed, but were filed back and cleaned off and greased with CeraTec where the pads rest. As the original disks had warped slightly, I have been checking to ensure they are not overheated when I Stop. One disk is slightly warmer than the other, but has become less so over three 50 mile journeys. Would this be part of the normal bedding in, or should I just bite the bullet now and strip it all out again? I think I know what most people will answer, but I am leaning towards seeing what it is like after 500 miles of bedding in.
Post #475491 11th Apr 2018 4:12pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Leave it and see - could be as simple as one is getting more rainwater than the other so cooler ... is it kerb side that’s cooler?
You’ve change the bits that would cause sticking - the caliper 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #475511 11th Apr 2018 5:47pm
Webbie
It is the kerb side running slightly warmer.
Post #475513 11th Apr 2018 6:05pm
it's the pistons which are sticking ..clean those up and it should be ok.. ... - .- -.
Post #475514 11th Apr 2018 6:06pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
How hot is it getting?
Post #475522 11th Apr 2018 8:20pm
Webbie
Warm rather than hot. My concern is that it’s warmer than the other side, say by 50%, but no where as hot as both the fronts are after stopping. Nothing wrong with the fronts of course.
Post #475529 11th Apr 2018 8:46pm
