Home > Technical (L322) > Td6/Bmw - Intercooler to Turbo pipe
Gold Ranger
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
hoping to take the turbo to intercooler pipe off today ready for the new ones - any tips for easy removal / access please - td6 bmw model
cheers
Post #449313 28th Aug 2017 11:51am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Bump, I need to take mine off the check condition so looking for tips 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #475283 9th Apr 2018 9:09am
This, I believe is the most illuminating thread on the subject:
http://www.fullfatrr.com/forum/topic41974....ntercooler .
Post #475309 9th Apr 2018 2:49pm
wayneg
Thanks for the link, I would have just undone the jubilee clip before reading it. Not sure if that's my problem but I just want to discount any splits in the hoses. I might try getting an endoscope down there 1st. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #475342 10th Apr 2018 1:20am
Joncey
Jersey 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I replace all mine last year with silicone ones , at the intercooler end they are on a quick release clip which comes off nice and easy but I then found that once the jubilee clip was removed the pipe was bonded on to the inter cooler coupling so had to cut I all off with a stanly knife to be able to fit the coupling to the new pipe.
I would guess that the fitting come with a new pipe from LR
Post #475369 10th Apr 2018 2:21pm
holidaychicken
Intercooler end is a quick release spring clip that you pull down towards you from underneath
The turbo end comes off with the jubilee clip if you remove from the turbo but if you try and remove the pipe from either side of the metal joining thing that I don’t know what it does , the pipes are bonded to it and as above will need cutting off unless you buy the genuine part that comes with the metal joiner in place
What symptoms do you have ?
Post #475432 10th Apr 2018 10:44pm
wayneg
My symptoms are a loss of power under load followed by lumpy tickover. The tickover becomes ok after a few minutes. Have had the car on IPNA diagnostics I can find no real fault, the low-pressure fuel fluctuates a bit around 4bar, the high pressure is excellent. Boost pressure rises with revs, Injector figures all good. The engine starts instantly. No unusual noises. I am still driving the car daily, if driven carefully all seems ok. I think it is fuel starvation. I have already changed the fuel filter, plus have ordered both electric pumps, in tank and external. I can feel the external pump working, its not the original but no idea of age. Will be a couple of weeks until I get both pumps. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #475435 11th Apr 2018 1:38am
holidaychicken
Loss of power i would expect some codes, not sure what INPA covers.
Can you check your turbo actuator is moving freely ?
You can see it if you move the two large cable bundles that run along the edge of the inlet manifold on the offside wing. The actuator should move when the car is started to the fully closed position, towards the inner wing.
You could carefully disconnect one of the vacuum pipes on the inner wing reservoir or coming from the actuator solenoid to the turbo actuator and take it for a drive. You will lose low end power but it will tell you if it is turbo related if it doesnt lose power at high load as in overboosting due to stuck actuator.
Post #475525 11th Apr 2018 8:29pm
wayneg
IPNA is the BMW Dealer diagnostics so for the engine it covers everything. The icarsoft I have does the same in a portable unit. The IPNA is on a nice big screen laptop of mine so user-friendly. Not much use for a non BMW car though. I will take a look at the actuator as soon as I get a chance. Car is behaving perfectly at the mo. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #475547 12th Apr 2018 1:12am
wayneg
With the engine ticking over, whilst watching the actuator, I removed and replaced the vacuum hose several times and was pleased to see the actuator arm moving back and forth instantly so I will now discount Turbo and Boost issues. I am even more inclined now to believe that one of the electric fuel pumps is playing up. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #475549 12th Apr 2018 5:26am
holidaychicken
That’s good then, if the map sensor or solenoid is playing up then that should show codes so as you say it sounds like fuel. Can you get live data readings for fuel pressure?
Post #475796 13th Apr 2018 11:11pm
