Home > Technical (L322) > Td6/Bmw - Intercooler to Turbo pipe |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
Bump, I need to take mine off the check condition so looking for tips 2007 TDV8 VSE
9th Apr 2018 9:09am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
This, I believe is the most illuminating thread on the subject:
9th Apr 2018 2:49pm |
Thanks for the link, I would have just undone the jubilee clip before reading it. Not sure if that's my problem but I just want to discount any splits in the hoses. I might try getting an endoscope down there 1st. 2007 TDV8 VSE
10th Apr 2018 1:20am |
Joncey Member Since: 24 May 2014 Location: St Helier Posts: 53 |
I replace all mine last year with silicone ones , at the intercooler end they are on a quick release clip which comes off nice and easy but I then found that once the jubilee clip was removed the pipe was bonded on to the inter cooler coupling so had to cut I all off with a stanly knife to be able to fit the coupling to the new pipe.
10th Apr 2018 2:21pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Intercooler end is a quick release spring clip that you pull down towards you from underneath
10th Apr 2018 10:44pm |
My symptoms are a loss of power under load followed by lumpy tickover. The tickover becomes ok after a few minutes. Have had the car on IPNA diagnostics I can find no real fault, the low-pressure fuel fluctuates a bit around 4bar, the high pressure is excellent. Boost pressure rises with revs, Injector figures all good. The engine starts instantly. No unusual noises. I am still driving the car daily, if driven carefully all seems ok. I think it is fuel starvation. I have already changed the fuel filter, plus have ordered both electric pumps, in tank and external. I can feel the external pump working, its not the original but no idea of age. Will be a couple of weeks until I get both pumps. 2007 TDV8 VSE
11th Apr 2018 1:38am |
Loss of power i would expect some codes, not sure what INPA covers.
11th Apr 2018 8:29pm |
IPNA is the BMW Dealer diagnostics so for the engine it covers everything. The icarsoft I have does the same in a portable unit. The IPNA is on a nice big screen laptop of mine so user-friendly. Not much use for a non BMW car though. I will take a look at the actuator as soon as I get a chance. Car is behaving perfectly at the mo. 2007 TDV8 VSE
12th Apr 2018 1:12am |
With the engine ticking over, whilst watching the actuator, I removed and replaced the vacuum hose several times and was pleased to see the actuator arm moving back and forth instantly so I will now discount Turbo and Boost issues. I am even more inclined now to believe that one of the electric fuel pumps is playing up. 2007 TDV8 VSE
12th Apr 2018 5:26am |
That’s good then, if the map sensor or solenoid is playing up then that should show codes so as you say it sounds like fuel. Can you get live data readings for fuel pressure? |
13th Apr 2018 11:11pm |
