Home > Maintenance & Mods (L322) > Fault codes and check engine light... |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 732 |
That’s my point, the LPG can still cause problems even if you’re not using it. |
9th Apr 2018 4:42am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Good news - smoke test came back showing the bung had been left off the pcv! Guessing that could cause some issues! Is there more than one place the bing could go though as I watched the guy put it on unless he didn’t push hard enough - wondered if he could put in wrong place? Also nozzle for c8 gas was loose so will cover in gasket seal and tighten her up.
10th Apr 2018 9:35pm |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 |
Hey, did you get a resolution on this? My 2004 M62 on dual fuel has the same / similar issue and has the mechanics stumped.
2nd Feb 2020 6:42am |
Mine was the pcv and the pcv bung and the the maf iirc...
2nd Feb 2020 9:09am |
