Hey, did you get a resolution on this? My 2004 M62 on dual fuel has the same / similar issue and has the mechanics stumped.
If I'm running on LPG at the end of my run, then the next morning when its cold, starting on petrol, it starts to run like a dog after about 10 seconds of idling with engine light flashing, codes indicate misfires in multiple cyls. It was a lot worse earlier on with stalling immediately after starting (maybe 3 or 4 times at its worst) then seemed to rectify itself over time, have no idea how.
However if I switch to petrol maybe 5 minutes before I stop my run for the day, the next morning is virtually trouble free.
dragging in air I thought had merrit, how would I check for this??. A leaking LPG injector on startup also was a possibility, but had that checked and discounted as the lock off valve doesn't open till later on when she's warmer.
I've got a mate with a decent OBD II tool. its locked to his VIN but does show certain things on my car. I'll try it.
Thanx Matt Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
1986 RRC Highline with offroad mods. Arctic Silver
2001 P38 HSE. Ardeness Green.
1995 RRC soft dash (beautiful car) Green.
2005 L322 HSE V8. - Current, most awesome car yet. And most expensive.
