Home > Maintenance & Mods (L322) > Converting to 13pin
supershuttle
Converting to 13pin
My car currently has two 7 pin sockets for the towing electrics, I don't tow I just have a bike rack with 13 to 7 pin adapter. Is there any reason not just to swap the twin 7 pin sockets on the car for one 13 pin. I do use a c-tech to charge through the white 7 pin socket but I am sure I can change that as well.
Anything to watch out for and if anyone has done it a source for 13pin plugs and sockets. Geoff
Post #475011 6th Apr 2018 2:07pm
I did it - a bit fiddly but fairly straightforward.
I got mine off eBay.
IIRC mine had some kind of resin in the sockets, so I had to cut the cable & strip back the wires.
Post #475012 6th Apr 2018 2:19pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
You can buy from LR a single 13 pin connector cost about £100 simple plug and play, I got mine through eBay which is a Landrover main agent so could give a discount.
Post #475032 6th Apr 2018 4:33pm
But if you already have the cabling, its £7.49 delivered and connect up 13 wires - depends on how handy you are I suppose......
Post #475038 6th Apr 2018 5:21pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Think the 13 pin socket is tested as part of the MOT, 7 pins are not. 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #475039 6th Apr 2018 5:28pm
