Home > Maintenance & Mods (L322) > Converting to 13pin |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
My car currently has two 7 pin sockets for the towing electrics, I don't tow I just have a bike rack with 13 to 7 pin adapter. Is there any reason not just to swap the twin 7 pin sockets on the car for one 13 pin. I do use a c-tech to charge through the white 7 pin socket but I am sure I can change that as well.
6th Apr 2018 2:07pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
You can buy from LR a single 13 pin connector cost about £100 simple plug and play, I got mine through eBay which is a Landrover main agent so could give a discount. |
6th Apr 2018 4:33pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
But if you already have the cabling, its £7.49 delivered and connect up 13 wires - depends on how handy you are I suppose...... |
6th Apr 2018 5:21pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Think the 13 pin socket is tested as part of the MOT, 7 pins are not. 56 TDV8 Vogue SE
6th Apr 2018 5:28pm |
