Home > Maintenance & Mods (L322) > ZF 8 speed fluid and filter change 2011 TDV8 4.4 |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
Thanks!!I am having the service done at ZF on monday.Will make sure they replace all the bits they remove!
5th Apr 2018 7:28pm |
Sounds like you're having fun CoB. Very helpful write up.
5th Apr 2018 8:01pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
GREAT stuff well done, you make it sound simple. Would you say a day taking your time would be ok to do full fluids change - the auto box, transfer box, and 2 x diffs - and engine oil COB? Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
5th Apr 2018 8:06pm |
Oh after you filled the initial 3 litres - did you top it up by much - how many litres all-in did you use?
5th Apr 2018 8:10pm |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
GonnaGoDouble - I'd say you'd need most of a day to do all those fluids/oil; assuming it's your first time. The diffs and transfer box probably take less than an hour to do if you're hurrying, but I was being very careful. For instance, simply filling, refilling and squirting (ooer matron) the syringe takes some time. And you always seem to encounter some nut or bolt that you can't easily get to. And the filler holes seem to be placed in the most inaccessible places! Apart from the transfer box - that really is simple, the easiest of the lot.
6th Apr 2018 10:02pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 329 |
I used one of these for the transmission fluid - cheap, simple and no mess
7th Apr 2018 12:42pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 747 |
I've done mine twice recently, once just the oil then again a few months later with a new filter. On both occasions it took close to 5 litres to fill it up. I don't doubt the figure of 3 and a bit litres as the lad helping me who has more experience with these boxes was surprised when we opened the 5th bottle. Our conclusion was that temperature and/or differences in degrees of tilt may have a bigger effect than you might expect. I've only mentioned this as I would hate to see someone do this armed with only 4 litres! |
7th Apr 2018 2:21pm |
Agreed cass, you probably don't need the ten litres I had, but I'd want to have five or six litres on hand. |
7th Apr 2018 6:11pm |
Had the box flushed and filter change,all by ZF service centre....very happy!Box shifting very smooth!No reset on the 8 speed box,the box does this continually. 2012 TDV8 Vogue SE 4.4 |
12th Apr 2018 5:21am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
Just a quick (probably dumb) question, is the final top up done with the engine still running? 2010 4.4 TDV8 Vogue SE |
12th Apr 2018 6:53am |
Yep , and at the right temp 4.2 SC - sold , now bought back
12th Apr 2018 10:12am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8641 |
reading the LR Bumf on doing this,
13th Oct 2018 10:38am |
I ran mine up to temp beforehand draining the fluid (6sp) .. then left if for a while to get out as much fluid as possible
14th Oct 2018 11:33am |
Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116 |
Can you do this change without a diagnostic tool? |
16th Oct 2018 12:41pm |
