Home > Maintenance & Mods (L322) > ZF 8 speed fluid and filter change 2011 TDV8 4.4
Page 4 of 4 <1234
It all depends on how much you like getting dirty and how decent you are at spannering.
It’s not a hard job, and actually quite satisfying once you’ve done. So long as you follow the general principles on this thread then you can’t go far wrong.
It can be a messy job but if you fancy a bit of spanner it and have a clean hard floor do it on then no reason not to. Nothing against the Bodsy idea but if you are willing and have the tools, fancy a bit of a job on, then crack on with it. There is nothing that can't be fixed with a hammer😜😜
Post #572700 13th Nov 2020 6:36pm
Jameo84
Scotland 2012 Range Rover Westminster 4.4 V8 Java Black
Done with help from this guide
Done the service using this guide. I used west way oils for the gearbox. Used 5l bang on. I got two so will change it over again in in the next few weeks.
The old oil was quite dark brown black on 80k on a 2012 so glad I started changing it.
Got the service kit from Maltings “eBay shop”
Post #574665 30th Nov 2020 8:10pm
Mikey
Flushed an 8 speed this morning, also around 80k...
Post #574699 30th Nov 2020 10:38pm
DrRob
Mine at 83K last year. Megaflush by Bodsy Thumbs Up
Old oil wasn’t too bad Thumbs Up
 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #574700 30th Nov 2020 10:47pm
Page 4 of 4 <1234
