![]() | Home > Technical (L322) > Exhaust gas in coolant, head gasket failure or not? |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Voguevague
Voguevague Member Since: 01 Apr 2018 Location: Athens Posts: 17 ![]() ![]() ![]() |
Thanks Mark for this reply, really helpful and somewhat reassuring that you agree with my trusted independent.
axe Member Since: 01 Mar 2016 Location: Stockholm Posts: 3 ![]() ![]() ![]() |
Does the 5.0 have an oil cooler? I never checked mine. If it has a small leak maybe that could be a possible source? |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 830 ![]() ![]() ![]() |
When I had suspected head gasket failure I had the sniff test done and like yours came back clear.
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Don't be tempted by miracle cure additives - the myriad of tiny galleries that exist in modern engines (so I am told by grown ups |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
This is what I found in my radiator when I took it off.
yak, |
[quote="axe"]Does the 5.0 have an oil cooler? I never checked mine. If it has a small leak maybe that could be a possible source?[/quote
My thoughts too Bish. All too good to be true! |
Simon, Thank you for your reply here. I take some comfort in what your mechanics say "if you have residual pressure in the system after leaving it overnight etc, then you do not have a blown head gasket. If you did have a blown head gasket then all of that pressure that had built up would eventually bleed away through the faulty head gasket and leave you with no pressure in the system". So the bogey man remaining out there for me, is the positive test for exhaust gases in the coolant reservoir, I may try a coolant change and retest. On another point but related. On grasping for clues I purchased a new radiator cap (OEM) and fitted. For some reason the cap does not tighten or give the resounding click to stop turning. Took car out for drive ,left overnight and low and behold no pressure next morning! Need to retest with old cap now. Gets more curious! Keith |
[quote="UK Marine"]When I had suspected head gasket failure I had the sniff test done and like yours came back clear.
Sorry, I don't know how I missed 4.2. I was thinking maybe the leak would be small enough only to let the crankcase gases escape into the cooling system, with the oil pressure being higher than the coolant pressure. This is high speculation though, hope you will find the root cause being something simple. |
