Home > General > I got stuck !!!
This feature was demonstrated at the Land Rover Experience Offroading day be selecting "Rock Crawl" mode. We drove through a section where one of the front wheels and one of the back wheels was always hanging in the air and the two remaining wheels coped perfectly while the hanging wheels remained still Thumbs Up
Post #47459 25th Jan 2011 6:39pm
Fox
The locking diff is more useful at low speed where it can be locked depending on the terrain response setting, such as rock crawl.
Otherwise you need to provoke slip (hence my full throttle comment) to get the traction control working properly.
I have got stuck twice in my old TDV8. Both times turning off DSC (it was already off) and then applying full throttle told the car I was stuck and it used it's brain to work out where there was and wasn't grip, before pulling me out. In both situations if I had messed about with settings and tried to drive I'd still be stuck. You have to tell the car you are stuck and the wheels are slipping by upping the power, then it will send the power where it needs to so you get out.
Post #47479 25th Jan 2011 7:46pm
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
Winch. It can sometimes help to overcome traction issues. Very Happy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Not sure you should be reading this bit.
Post #47570 26th Jan 2011 10:25am
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I might go back t the same spot and re create the situation and try what fox said ! 2007 TDV8 Vogue SE
Post #47571 26th Jan 2011 10:27am
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
yea use the rev the granny out of it in temper, works everytime.... Laughing 2004 black Vogue TD6
Post #47837 27th Jan 2011 5:27pm
