Home > Technical (L322) > 2010 TDV8 SE heated seat problem !!!!!!!
Rob199027
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi there
Got a 2010 SE drivers seat heated and cooled seat has stopped working !!! Switch still lights up etc any help or this another thing going to cost 1000s to fix lol Rolling with laughter
Post #474425 31st Mar 2018 3:21pm
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Try this thread: - http://www.fullfatrr.com/forum/topic44946....ated+seats
Post #474433 31st Mar 2018 3:44pm
GGDR
Not £1000's Rob, should be a £225 part. If both units gone (like mine), might be double that. If you do it yourself that is. As above, read through that thread there's a bunch of us like you over there!
Cold seats are not at all the Range Rover experience.
. Cheers, Greg
Post #474441 31st Mar 2018 4:33pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Check the other thread and especially to determine if it's Base and/or back that don't work.
Also check if the fans work on cooling.
Oh, and if you can, use an obd tool to get any related fault codes. This will help greatly to identify where the fault lies. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #474459 31st Mar 2018 8:48pm
Rob199027
Cheers guys checked the seat out yesterday cooling is still working, going to try it just on the back see if it heats up thanks for help
Post #474477 1st Apr 2018 8:50am
