![]() | Home > Technical (L322) > Drivers window not closing properly at speed |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
Are you actually able to tell that the window is not fully shut? I'd have thought that once it was shut it would stay in the same place regardless of speed, and that the problem was more to do with the door seal being defective. That has happened with mine, it was repositioned or replaced under warranty (not sure what the dealer did) and that solved it for quite a long time, but there were occasions latterly when there was a bit of noise (irritating) and pressing the window button confirmed it was fully shut. I'd start by checking the seal. Only Range Rovers since 1988 |
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 100 ![]() ![]() ![]() |
It runs slighty out of the seal when closing at speed so it's shut but not sealed . |
GavinBell Member Since: 10 Sep 2017 Location: Phnom Penh Posts: 88 ![]() ![]() ![]() |
and with the auto close - goes straight back down. Most disconcerting when it first happens 24 hours after picking up car and on the German autobahn enroute for Romania - visions of a long cold drive! Just have to slow down and wind it up! Series 2a LWB Hardtop - ex British Aerospace that was then used in an armed robbery! not by me!
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1200 ![]() ![]() ![]() |
Try opening another window slightly to reduce the pressure of sucking the window out thats how I over come the problem? |
Slowing down to 60 works , it doesn't drop back down thankfully just doesn't seal properly , tried opening all the other windows to aleviate any pressure to no avail |
Popeye Member Since: 15 Sep 2017 Location: Kent Posts: 27 ![]() ![]() ![]() |
I get the same. I take the window upto the final inch or so then just edge it up a few millimetres at a time. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
you could fit window wind deflectors .. ... - .- -.
