Home > Technical (L322) > Drivers window not closing properly at speed
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
As per title , my drivers window doesn't quite close fully when going more than 65 mph , makes a bloody din with wind noise , any ideas ?
Post #474238 29th Mar 2018 10:12am
CS
Are you actually able to tell that the window is not fully shut? I'd have thought that once it was shut it would stay in the same place regardless of speed, and that the problem was more to do with the door seal being defective. That has happened with mine, it was repositioned or replaced under warranty (not sure what the dealer did) and that solved it for quite a long time, but there were occasions latterly when there was a bit of noise (irritating) and pressing the window button confirmed it was fully shut. I'd start by checking the seal. Only Range Rovers since 1988
Post #474240 29th Mar 2018 10:26am
matthews
It runs slighty out of the seal when closing at speed so it's shut but not sealed .
Post #474243 29th Mar 2018 10:46am
GavinBell
Romania 2012 Range Rover Westminster 4.4 V8 Santorini Black
and with the auto close - goes straight back down. Most disconcerting when it first happens 24 hours after picking up car and on the German autobahn enroute for Romania - visions of a long cold drive! Just have to slow down and wind it up! Series 2a LWB Hardtop - ex British Aerospace that was then used in an armed robbery! not by me!
2 door V8 1979 Range Rover
A slight Subaru blip..
110 County 200tdi
R reg 300 tdi Discovery Aviemore - gone to a local enthusiast to be resurrected in Transylvania
2003 TD5 Discovery2 - now sold
and the 2 wheeled Range Rover - BMW R 1150GSA
and finally the big lady of my dreams... 2012 Westminster - gives me a smile every morning
Post #474244 29th Mar 2018 11:13am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Try opening another window slightly to reduce the pressure of sucking the window out thats how I over come the problem?
Post #474245 29th Mar 2018 11:14am
matthews
Slowing down to 60 works , it doesn't drop back down thankfully just doesn't seal properly , tried opening all the other windows to aleviate any pressure to no avail
Post #474260 29th Mar 2018 1:46pm
Popeye
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I get the same. I take the window upto the final inch or so then just edge it up a few millimetres at a time.
Post #474263 29th Mar 2018 2:15pm
you could fit window wind deflectors .. ... - .- -.
Post #474264 29th Mar 2018 2:21pm
