Home > Technical (L322) > EGR blanking on a 4.4 TDV8 2012 model year |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
why would you want to do this Mike? ... - .- -.
28th Mar 2018 9:26am |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
Good question Stan, I suppose I just dislike the idea of sooty gases being pumped back in to the engine. The remap companies say that the software side of things is free; i.e. it's part of any remap - which I'm toying with as a way of improving the low speed response of the car (I'm not interested in huge bhp or torque gains that might break the gearbox).
28th Mar 2018 10:00am |
as you know the 4.4 tdv8 is a fairly complicated engine so messing with maps and egr might 'upset' the engines balance..
28th Mar 2018 10:23am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Mine's ecu is stock. I tried blanking EGR by inserting a thin plate between the join in the pipework just before the pipe enters the throttle body, sealed with high temperature silicone sealant. Whilst the engine responded beautifully to light throttle openings, much more smoothly and positively than normally, as soon as the throttle was backed-off to hold the revs steady the engine would die presumably due to engine management closing the throttle butterfly trying to increase exhaust gas flow. It was impossible to keep constant revs, only accelerating smoothly or abruptly decelerating with apparent closed throttle.
28th Mar 2018 10:38am |
Well, GraemeS's post sort of confirms your point, Stan. I'm wondering whether it's possible to deal with the only thing I dislike about how the 4.4 TDV8 drives - namely the lack of oomph from standstill. Once on the move, I find the acceleration more than adequate. And it's such a heavy old thing that you wouldn't want crazy performance anyway! But I would like better low speed response. |
28th Mar 2018 2:55pm |
you need to stop trying to race saxo's at traffic lights Mike ... - .- -.
28th Mar 2018 3:06pm |
...you could use sport mode if and when you needed it.. ... - .- -.
28th Mar 2018 3:26pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
Remap?
28th Mar 2018 3:29pm |
Removing the butterfly or somehow stop it from closing in addition to blocking the EGR tube may work, although without a butterfly the ecm can't block off air in the event of an engine runaway if the ecm has this functionality. |
28th Mar 2018 8:07pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
I spoke with our mappers ages ago and was told absolutely NOT to mess with the EGR on either the 3.0 or the 4.4 as it will cause DPF issues... So, please proceed with caution folks |
28th Mar 2018 8:17pm |
Some of us don't have DPFs. |
28th Mar 2018 11:19pm |
Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137 |
Superchips won’t remap a 4.4TDV8. When asked why not the response was “performance could not be improved without compromising reliability on this engine”. |
29th Mar 2018 6:14am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
Just a thought, I was asked by a friend to investigate an egr delete on a 2014 Pajero and found a mod online which I was able to complete for next to nothing. It was just a resistor to trick the engine ecu that the intake was cold even when the car was up to temp. This had the effect of never allowing the electric valve egr to open. This is well beyond my level of understanding but it works on the Paj, maybe some clever member might look into the possibility of the same on the 4.4TDV8. https://www.youtube.com/watch?v=CK5z2jyP-vY 2007 TDV8 VSE
29th Mar 2018 6:16am |
I would not want the engine to be run as though it was always cold. However I would happily have a remap that only set the minimum EGR temperature to an impossibly high temperature. |
29th Mar 2018 8:50am |
