Home > Technical (L322) > Fitting /re-fitting front driveshaft |
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 |
The way I did it was remove the gaiter from the diff end and using a length of 50x50 wood banged it back in with a lump hammer. then refit the gaiter with a large zip tie. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
20th Mar 2018 10:01am |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 |
When i did mine mate to get it back in i un did the bracket which the shaft slides through to give me more up and down movement it was still a ball ache though |
22nd Mar 2018 7:55pm |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Cheers guys, I guess I am surprised by how much effort it takes to get the driveshaft to seat in the diff.
23rd Mar 2018 11:27am |
Yes mate its like you have to bounce them in if you will but like i said i removed the alloy bracket that bolts to the motor which the shaft sits through it have me fair be of up and down movement |
23rd Mar 2018 11:36am |
Cool, I will get it up on the ramps then and give it a go with a bit better access!
23rd Mar 2018 11:42am |
Did you get sorted with the driveshaft re fitting pal |
29th Mar 2018 11:45am |
No, job for this weekend if all goes according to plan 2011 TDV8 AB
29th Mar 2018 9:26pm |
So got onto this yesterday, had to do it on axle stands in the end as it threw the Transfer box error/can't select neutral/no drive when I tried to move it onto the ramps
2nd Apr 2018 10:54am |
I have a clonck / knock on the left front of mine i have done the ball joints drop links etc im woundering if mine has a knackerd strut instead as the knock still there |
2nd Apr 2018 11:29am |
roblane65 Member Since: 01 May 2017 Location: Newcastle Upon Tyne. Posts: 83 |
Nice write up. Did the front diff on my SC sometime ago and it was a rite pain getting the d/shafts back in the front hubs, no idea why they are so tight. Getting them in the diff wasn't a a big deal though. Good one for doing your own work and sharing it with us all Range rover 4.2 SC 06MY. |
2nd Apr 2018 2:29pm |
RobL322 Member Since: 29 Sep 2021 Location: Yorkshire Posts: 32 |
getting stuck in replacing whole engine and want to remove driveshaft. (the donor engine arrived with front diff attached.
29th Sep 2021 5:14pm |
Got both driveshafts out.
23rd May 2022 12:13pm |
Rom Member Since: 11 Nov 2020 Location: Amsterdam Posts: 6 |
Hi All,
2nd Mar 2023 11:01am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1176 |
For re-fitting the front off-side drive shaft, here is one tip that worked for me.
2nd Mar 2023 1:45pm |
