![]() | Home > Technical (L322) > Fitting /re-fitting front driveshaft |
its me Member Since: 08 Mar 2013 Location: southampton Posts: 78 ![]() ![]() ![]() |
The way I did it was remove the gaiter from the diff end and using a length of 50x50 wood banged it back in with a lump hammer. then refit the gaiter with a large zip tie. 2011 4.4 tdv8 Kahn. 2007 supercharged with 2012 lights and overfinch body kit. P38 with a full J.E.Engineering conversion |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 ![]() ![]() ![]() |
When i did mine mate to get it back in i un did the bracket which the shaft slides through to give me more up and down movement it was still a ball ache though |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Cheers guys, I guess I am surprised by how much effort it takes to get the driveshaft to seat in the diff.
Yes mate its like you have to bounce them in if you will but like i said i removed the alloy bracket that bolts to the motor which the shaft sits through it have me fair be of up and down movement |
Cool, I will get it up on the ramps then and give it a go with a bit better access!
Did you get sorted with the driveshaft re fitting pal |
No, job for this weekend if all goes according to plan |
So got onto this yesterday, had to do it on axle stands in the end as it threw the Transfer box error/can't select neutral/no drive when I tried to move it onto the ramps |
I have a clonck / knock on the left front of mine i have done the ball joints drop links etc im woundering if mine has a knackerd strut instead as the knock still there |
roblane65 Member Since: 01 May 2017 Location: Newcastle Upon Tyne. Posts: 83 ![]() ![]() |
Nice write up. Did the front diff on my SC sometime ago and it was a rite pain getting the d/shafts back in the front hubs, no idea why they are so tight. Getting them in the diff wasn't a a big deal though. Good one for doing your own work and sharing it with us all |
RobL322 Member Since: 29 Sep 2021 Location: Yorkshire Posts: 32 ![]() ![]() |
getting stuck in replacing whole engine and want to remove driveshaft. (the donor engine arrived with front diff attached.
Got both driveshafts out.
Rom Member Since: 11 Nov 2020 Location: Amsterdam Posts: 6 ![]() ![]() ![]() |
Hi All,
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1233 ![]() ![]() ![]() |
For re-fitting the front off-side drive shaft, here is one tip that worked for me.
