![]() | Home > Technical (L322) > HDC, Air Sus inactive + general alarm issue |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 ![]() ![]() ![]() |
G'day.
Yup, most likely an ABS sensor or reluctor ring gone bad, given your symptoms.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Could just be that the front tracking is way out.
Hey Thanx guys for the valuable input.
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Just to add a quick check, pull the multiplug connector to the ABS ECU (front of the ABS pump block by the l/h suspension turret) and check for corrosion on the pins. Mine had this and caused similar symptoms.
Ok, all fixed.. $2200 later.. |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
Trouble with mechanics replacing things in hope they fix things and they don't, so you pay for all those unnessecary parts you ddin't need.. |
