Home > Maintenance & Mods (L322) > LED interior tailgate lights
deansmith
United Kingdom 2016 Range Rover Vogue SE SDV8 Carpathian Grey
Hi all,
Would anyone happen to know of any LED replacement bulbs for the interior tailgate hatch? I quite often have to sort through my gear in the boot and having some brighter lights would be beneficial.
TIA.
Post #473076 19th Mar 2018 9:23am
alistairh
I’ve used this kit and they are decent quality and made a diffrence https://rover.ebay.com/rover/0/0/0?mpre=ht...1698842066
Post #473089 19th Mar 2018 11:27am
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I've just done this and have had a battle and a half with the LEDs and the BCU seemingly having a mind of its own. It turned out (I think - fingers-crossed) that I'd disturbed one of the metal lamp-holders when I removed it and it's been making intermittent connection which throws things into turmoil and the BCU switches off all three lamps for an indeterminate amount of time (seems to be at least 30mins) before resetting.
Anyway, I ended up using these and they work well (and for under 50p each). https://www.ebay.co.uk/itm/CAR-SIDELIGHT-B...1796387343
I also used these in the door puddle lamps.
On my car the bulb in the loadspace itself is of a festoon type rather than a T10 so I've now ordered a different LED for that one.
Oh, and there's a good chance you'll break the plastic retaining clip when you remove the lamp from the tailgate itself. Go easy on it. I broke one of mine and the other ended up very loose. As a result I've had to improvise... Thumbs Up 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #473120 19th Mar 2018 5:07pm
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
I did a full interior led upgrade - includes the bulbs you mean - using this:
http://www.fullfatrr.com/forum/topic42027.html
But check for your MY. What do I put here then?
Post #473141 19th Mar 2018 8:37pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
As per GAC23, used the same kit on mine, all good and the boot is a lot brighter now! 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #473172 20th Mar 2018 1:32am
MikeO
If it's just the loadspace you want to do then for less than a fiver you just need:
1 x https://www.ebay.co.uk/itm/C5W-Car-Bulb-LE...2494717651
2 x https://www.ebay.co.uk/itm/CAR-SIDELIGHT-B...1796387343
I had the chance to test mine last night and it's very bright - a big improvement over the originals. Do double check the lamp types you have - mine's a 2009 and the one in the loadspace is a "festoon" type bulb whereas the two in the tailgate are T10. This seems to have changed on different MYs. Also see this thread: www.fullfatrr.com/forum/topic13609.html
If you want to do the whole car you can go the easy route and order a kit of just buy the bulbs yourself and save some £££. 2016 Skoda Octavia VRS Estate
Post #473174 20th Mar 2018 8:48am
deansmith
Thanks all! I've ordered the kit from ebay. I have already replaced the festoon luggage space light with an LED from a number plate light upgrade.
Cheers!
Post #473368 21st Mar 2018 10:24pm
