Home > General > What Did You Do In Your Full Fat Today |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 |
And today I fitted the new wheel. Feels a lot better and heats up lovely. |
16th Mar 2018 8:14pm |
New drop links fitted today is a lovely quite place to be again. |
20th Mar 2018 4:41pm |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
Got my key cover makes it look alot nicer then before. £1.33 from china.
21st Mar 2018 1:37pm |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 |
Took advantage of a break in the weather to get the salt and grit off the car. First up on ramps to scrub the underside
22nd Mar 2018 4:10pm |
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 |
Just fitted some new tyres Lets Off Road
22nd Mar 2018 6:35pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Nice run to Inveraray and a great lunch in The George Hotel
24th Mar 2018 4:47pm |
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 208 |
In a flurry of activity today I've replaced both rear light assemblies, like-for-like from Powerful UK and fitted clear lenses to the side repeaters. Also took the rear wiper arm apart to try to find out why I only get a trickle of water - eventually! - out of the rear washer. I was expecting to see some sort of sealing O-ring between the supply pipe stub and the cap with the jets in but nothing - more work required on that front. Mind you, the arm itself has seen better days so perhaps a new one is on the cards. I've finally exhausted all options in trying to locate a replacement rear wiper cover trim panel so it looks like I'll be getting in touch with Dan again; it was u/s when I got the car, a hole the side of a tennis ball in the middle and two lines of Araldite where a previous owner has done a bodge job! Oh, and I've also ordered a pair of upgrade headlamp bulbs from Amazon, they should arrive tomorrow. Nearest crocodile to the canoe after that is the aircon condenser; new one is sitting in the shed - and if tomorrow is decent weather-wise, it'll be fitted then.
24th Mar 2018 5:00pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3764 |
Inspired by the pictures of professional detailed cars, I got the bucket and sponge out.
26th Mar 2018 1:34pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 327 |
Changed the transmission fluid , filter and mechatronic sleeve .. then ran and dropped the fluid again another couple of times
26th Mar 2018 3:27pm |
Wasn't today but yesterday took it for a MOT and it Passed with flying colours |
27th Mar 2018 7:23pm |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 250 |
Replaced key battery and fitted new wipers. Remember:- amateurs built the ark
31st Mar 2018 10:53am |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
Filters and oil changed, hit the 100k club |
1st Apr 2018 12:24pm |
Got the FF thoroughly washed, waxed (including rear inner arches), carpets/mats cleaned and leather treated today.... |
1st Apr 2018 3:55pm |
Wogger Member Since: 12 Jun 2016 Location: Nottinghamshire Posts: 407 |
Got it back from the body shop, tailgate rust sorted !!
5th Apr 2018 12:39pm |
