![]() | Home > Maintenance & Mods (L322) > How to remove lower map pocket trim? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
i think its door card off and undo from back.. ... - .- -.
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Do your armrest while you have the door card off. If you have been lucky enough to not have had a need to pull the card before the center clip can be rather stuck to yank on. Be careful not to pull too far and break a wire. |
RRAustria Member Since: 07 Apr 2015 Location: Graz Posts: 32 ![]() ![]() ![]() |
Thanks! I managed to take the trim off - there are two nuts on the back that need to be removed. |
