Home > Maintenance & Mods (L322) > How to remove lower map pocket trim?
RRAustria
Austria 2004 Range Rover HSE Td6 Bonatti Grey
I need to remove the wood trim of the map pockets on the front door cards. How do you do it? I'm talking about the wood trim in this picture at the very bottom (ignore the arrow):
Thanks
Post #472851 16th Mar 2018 7:44pm
i think its door card off and undo from back.. ... - .- -.
Post #472853 16th Mar 2018 7:46pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Do your armrest while you have the door card off. If you have been lucky enough to not have had a need to pull the card before the center clip can be rather stuck to yank on. Be careful not to pull too far and break a wire.
Post #472855 16th Mar 2018 8:07pm
RRAustria
Thanks! I managed to take the trim off - there are two nuts on the back that need to be removed.
Post #473396 22nd Mar 2018 9:50am
