![]() | Home > Technical (L322) > Power steering groan. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I would change change PAS fluid an see if it helps.
lewis93 Member Since: 23 May 2017 Location: kent Posts: 28 ![]() ![]() ![]() |
I’ve had the reservoir replaced at £140 which didn’t work.
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
If the fluid level is dropping presumably it is leaking out somewhere, you need to find where before replacing parts. |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
Oil coolers are very common for leaking
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
Unnecessary quote removed
Thanks for the input everyone, my car is finally fixed!
