Home > Technical (L322) > Power steering groan. |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
I would change change PAS fluid an see if it helps.
13th Mar 2018 4:44pm |
lewis93 Member Since: 23 May 2017 Location: kent Posts: 28 |
I’ve had the reservoir replaced at £140 which didn’t work.
13th Mar 2018 5:40pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
If the fluid level is dropping presumably it is leaking out somewhere, you need to find where before replacing parts. |
14th Mar 2018 9:57am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1765 |
Oil coolers are very common for leaking
14th Mar 2018 5:09pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Unnecessary quote removed
14th Mar 2018 5:24pm |
Thanks for the input everyone, my car is finally fixed!
16th Mar 2018 4:08pm |
