Home > Wheels & Tyres > Fitting new 20’’ L405 alloys & 4wheel alignment
V8rumbler
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Ipanema Sand
Hi guys :- bought a lovely set of L405 20’’ wheels . I have booked her in to have the balance checked,wheels fitted and 4wheel alignment done . Is there anything I need to ensure the garage does ref: ride height, when changing the wheels
 2007 Vogue TDV8 in Stornoway Grey with Jet interior NOW SOLD
2011 (12MY) 5.0 S/C AUTOBIOGRAPHY ipanemaSand with Jet Interior
Post #472093 11th Mar 2018 9:33am
GAC23
United Kingdom 2015 Range Rover Vogue SE SDV8 Indus Silver
Unless you’re not already running on 20” wheels, I’d say that’s all. What do I put here then?
Post #472098 11th Mar 2018 9:52am
V8rumbler
Currently on 19’’. More concerned about which height to set the fat to before wheels are swapped etc 2007 Vogue TDV8 in Stornoway Grey with Jet interior NOW SOLD
Post #472102 11th Mar 2018 10:20am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
They have the same rolling radius so nothing to do unless you up to the 255/ 55 r20 tyre. Standard being 255/ 50r20. The speedo will read correctly in that case instead of overeading as standard. ( Its so you dont speed as you think your going faster than you are Wink ) 7% overread is normal.
The new wheels have different offset so will give more inner arch clearance and "fill" the arch for a better look.
You can let the car know its now on 20" rims via a diagnotic tool but I didnt bother. You will have no issues and can do it later if you wish. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #472109 11th Mar 2018 10:54am
GAC23
Fitters should sort that
Think they put mine into access mode to do it. What do I put here then?
Post #472110 11th Mar 2018 10:56am
V8rumbler
Unnecessary quote removed
The new tyres are 255 55r20. I assume therefore that my overall wheel diameter is larger and Speedo will be slightly wrong 2007 Vogue TDV8 in Stornoway Grey with Jet interior NOW SOLD
Post #472116 11th Mar 2018 11:54am
Grofus
The speedo will be correct on the new tyres.
They are designed to overread from the factory.
So on the original tyres, the speedo would be showing 60mph, actual speed would be 57mph.
On the larger tyre it takes that error out so it is accurate. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #472117 11th Mar 2018 12:00pm
Yes but its only a very small amount... Thumbs Up
Post #472118 11th Mar 2018 12:00pm
V8rumbler
All sorted - very pleased
Post #473017 18th Mar 2018 11:18am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Who did u use for 4 wheel tracking and how much please?
Post #473019 18th Mar 2018 11:40am
V8rumbler
I use my local garage - a very reasonable £48 inc
Post #473021 18th Mar 2018 11:50am
Dolphinboy
Jeez that’s cheap. May be worth a nice day out in yalmpton then! Many thanks 👍
Post #473029 18th Mar 2018 12:48pm
