Home > Wheels & Tyres > Fitting new 20’’ L405 alloys & 4wheel alignment |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
Unless you’re not already running on 20” wheels, I’d say that’s all. What do I put here then? |
11th Mar 2018 9:52am |
V8rumbler Member Since: 07 Mar 2018 Location: Devon Posts: 113 |
Currently on 19’’. More concerned about which height to set the fat to before wheels are swapped etc 2007 Vogue TDV8 in Stornoway Grey with Jet interior NOW SOLD
11th Mar 2018 10:20am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
They have the same rolling radius so nothing to do unless you up to the 255/ 55 r20 tyre. Standard being 255/ 50r20. The speedo will read correctly in that case instead of overeading as standard. ( Its so you dont speed as you think your going faster than you are ) 7% overread is normal.
11th Mar 2018 10:54am |
Fitters should sort that Think they put mine into access mode to do it. What do I put here then? |
11th Mar 2018 10:56am |
Unnecessary quote removed
11th Mar 2018 11:54am |
The speedo will be correct on the new tyres.
11th Mar 2018 12:00pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Yes but its only a very small amount... |
All sorted - very pleased
18th Mar 2018 11:18am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3164 |
Who did u use for 4 wheel tracking and how much please? |
18th Mar 2018 11:40am |
I use my local garage - a very reasonable £48 inc
18th Mar 2018 11:50am |
Jeez that’s cheap. May be worth a nice day out in yalmpton then! Many thanks 👍 |
18th Mar 2018 12:48pm |
