Home > My Range Rover > My First Range Rover
DJM911
United Kingdom 2009 Range Rover Vogue TDV8 Buckingham Blue
https://bellautoservices.co.uk/store/range...ack-5-ply/
Found these online. They seem like what I am after.... 2009 Land Rover Rang Rover Vogue TDV8 - Buckingham Blue with Ivory Leather - 20” Alloys with Pirelli’s
Post #472019 10th Mar 2018 6:26pm
As a job it’s a one spanner difficulty👍🏻
Can be done with a screwdriver in about 10 mins. Doing the top ones is all that needed, even with no mechanical know how it’s a simple and easy job to do. Doesn’t need a mechanic.
Have a look at this how to for the repair to one.
http://www.fullfatrr.com/forum/topic26843.html There is nothing that can't be fixed with a hammer😜😜
Post #472034 10th Mar 2018 7:39pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I got the 6 hoses set , didn't fit the two turbo ones until i had replaced but the other 4 weren't too bad to do. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #472057 10th Mar 2018 9:12pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Try these for your Mainbeams. They need a bit of fettling to fit but worth the effort.
https://www.ebay.ie/itm/H7-110W-20000LM-LE...1438.l2649
You may want these too if you don't want to alter the original bulb holders.
https://www.ebay.ie/itm/For-VW-Passat-B5-5...1438.l2649
You have to pull off the metal H7 collar from the bulb and fit the adaptor on, then re-fit the collar.
Its obvious how to do it when the parts are in front of you. The fiddly bit is turning the assembled bulb into the housing. I loosened off the torx bolts, turned it home then re-tightened the torx bolts.
The light output is brilliant Thumbs Up
My fatty with LEDs
Close up
Those trees are 50 yds away 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #472067 10th Mar 2018 10:23pm
DJM911
Any chance you fancy a run up north soon and do mine lol ahaha looks an unreal job! 2009 Land Rover Rang Rover Vogue TDV8 - Buckingham Blue with Ivory Leather - 20” Alloys with Pirelli’s
Post #472194 11th Mar 2018 9:10pm
