Home > General > Drivers door won't open |
CyberMrT Member Since: 26 Mar 2010 Location: Stratford upon Avon UK Posts: 60 |
I had this when we had all the snow, drivers door handle would pull open but door would not. Could open from the inside but not the outside. Assume the cable and lock had all frozen.
23rd Jan 2011 7:20pm |
Jer Member Since: 10 Dec 2010 Location: South Lanarkshire Posts: 15 |
I was hoping it would just defrost as it has done before but I think something has stuck this time. |
23rd Jan 2011 7:46pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
mechanism may have jammed, try pushing the cill lock button down hard from inside - it freed mine... may need a pointy stick as it will be flush with top of door card |
23rd Jan 2011 7:48pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
Will it open from inside? Just to eliminate the cable to the outside handle?
23rd Jan 2011 8:13pm |
Thanks, will try this in the morning. If I lock the door and pull the door handle inside, the cill button pops to unlock but the door does not open. |
23rd Jan 2011 8:38pm |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 |
I had this a few weeks back when the weather was really cold. The mechanism had jammed and the door would not latch shut. I took the door card off and freed up the mechanism where the exterior handle cable attaches.
23rd Jan 2011 9:52pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35425 |
the only way to totally solve this problem is to remove the mechanism and grease and lubricate with silicon spray...you can try spraying via the door lock holes but this will not work properly..
24th Jan 2011 8:56am |
