Home > General > Drivers door won't open
Jer
Scotland 2004 Range Rover Vogue 4.4 V8 Atacama Sand
Having a problem with my Range Rover (L322). When it gets cold the exterior drivers door handle would stick open due to it icing up. The door would open but when you tried to shut the door it would just bounce open. This happened last week so I locked the door from the inside and the door closed.
I now can't get the door open. I have tried opening it from the inside, the outside and they key seems to work okay locking and unlocking the door but the door won't open.
Has this happened to anyone else? I don't think the door panel will come of unless the door is open so i'm not sure how I can fix it?
Post #47168 23rd Jan 2011 7:12pm
CyberMrT
2003 Range Rover Vogue 4.4 V8 Stornoway Grey
I had this when we had all the snow, drivers door handle would pull open but door would not. Could open from the inside but not the outside. Assume the cable and lock had all frozen.
Thought I'd broken mine when I couldn't shut it once I'd managed to get it open, just bounced open like yours.
Once it had warmed up after a few days all worked ok again? L322 2002 4.4 V8 LPG
Post #47169 23rd Jan 2011 7:20pm
Jer
I was hoping it would just defrost as it has done before but I think something has stuck this time.
Post #47172 23rd Jan 2011 7:46pm
Vogue
mechanism may have jammed, try pushing the cill lock button down hard from inside - it freed mine... may need a pointy stick as it will be flush with top of door card
Post #47173 23rd Jan 2011 7:48pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Will it open from inside? Just to eliminate the cable to the outside handle?
I have a new cable to fit when I get some round tuits.
I also understand from recent threads here that the main culprit in cold weather is the mech jamming.. most likely due to de-icer slush freezing on it or just retained moisture and condensation. Cure is to rub a sheep around it as the lanolin repels moisture which is why sheep stay dry. If you don't have a sheep to hand then any suitable water repelant / lubricant of choice will be better than none. Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #47176 23rd Jan 2011 8:13pm
Jer
Thanks, will try this in the morning. If I lock the door and pull the door handle inside, the cill button pops to unlock but the door does not open.
Post #47178 23rd Jan 2011 8:38pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
I had this a few weeks back when the weather was really cold. The mechanism had jammed and the door would not latch shut. I took the door card off and freed up the mechanism where the exterior handle cable attaches.
Now unfortunately I'm not sure why your door will not open when it is unlocked. The only way to access the locking mechanism is to remove the door card, which requires he door to be open.
Now you may (and I am not sure on this) be able to get the AA or RAC to get you into you car in the same manner as they would when you are locked out. I don't know how is would work but it is worth a try. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #47189 23rd Jan 2011 9:52pm
the only way to totally solve this problem is to remove the mechanism and grease and lubricate with silicon spray...you can try spraying via the door lock holes but this will not work properly..
btw,loads of discussions about this can be found via the search ..
Post #47216 24th Jan 2011 8:56am
