Home > Technical (L322) > Suspension Heights? Newbie go easy. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Well you should be 493 front and 483 rear, but there can be a variance/tolerance of up to 10mm either way when recalibrating, on each corner.
5th Mar 2018 1:28pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8621 |
tricky to tell as unless you are parked on completely flat and level ground, there can be discrepancies.
5th Mar 2018 7:30pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
I lowered my running height by 15mm all round using the IID tool as it just looked too high.
5th Mar 2018 11:06pm |
stapsy Member Since: 17 Jan 2018 Location: Cambridge Posts: 3 |
Ok thanks guys..was thinking of lowering as read some say it handles better and plants better on the road. But on 22” so maybe not the best thing to do regards harsh ride!
5th Mar 2018 11:33pm |
If you have the ability to lower it via an IID tool or similar then just try it and see if you like it.
6th Mar 2018 8:05am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
as Paul says , as the GAP iidtool saves the original config on activation you can revert if you dont like the new heights or if you mess it up .. ... - .- -.
6th Mar 2018 8:14am |
We went out shopping last night and knowing the car park was flat I took the tape measure and IID tool with me.
20th Mar 2018 9:24am |
Massie0787 Member Since: 14 Mar 2018 Location: St Helens Posts: 11 |
Hi all the llD tool has anyone got a make and model. My suspension is different on all corners on a flat service. I want it to be standard height as I think it is around 20mm low all round and access mode doesn’t work or it doesn’t level out properly when been parked for a while. It’s a L322. Any help much appreciated. |
20th Mar 2018 6:46pm |
GAP IID. Site sponsors |
20th Mar 2018 6:48pm |
Anyone selling a secondhand one 🤣 |
20th Mar 2018 7:30pm |
There was a couple of non Bluetooth ones, which is what I have, in the classifieds |
20th Mar 2018 7:34pm |
Will they do the height adjust ment setup? |
21st Mar 2018 6:24am |
Yes |
21st Mar 2018 9:50am |
have a read of the manual,
21st Mar 2018 9:58am |
