Home > In Car Electronics (L322) > Ignition controlled fuse ?? |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
you not got a multi metre pal ? just test each fuse ignition on then off |
24th Feb 2018 6:39pm |
philip600 Member Since: 04 Feb 2018 Location: North East Posts: 36 |
Hi, I have got a multimeter yes but as I understand it some circuits take a while to shut off after locking the car & ive already tried 3 circuits I would have though would be dead when the car is locked ? That & the fact that it's pretty difficult to connect a multimeter to a fuse, shut the door & then lock the car & then wait till it goes to sleep ? |
24th Feb 2018 7:47pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1446 |
On my 2012 Westie I have dashcam connected to F53 which is a spare with the right hand terminal live when ignition on. F54 is the same.
24th Feb 2018 10:43pm |
Cheers for that, will try one of those 👍 |
24th Feb 2018 11:16pm |
Rob99, thanks for your advice, fuse 53 & 54 both had 20amp fuses fitted on my 2012 Westminster although they are listed as spare in the owners manual ? Anyway I've used a piggyback fuse plugged into 53 & now have a dashcam that switches on & off with the ignition so happy days so thank you 😀 |
25th Feb 2018 8:40pm |
I guess yours must have some other option which needs the extra fuses.
25th Feb 2018 8:56pm |
