Home > In Car Electronics (L322) > Ignition controlled fuse ??
philip600
Hi, I've fitted a nextbase dashcam in my 2012 l322, I originally had it plugged into the accessory socket which turns on & off with the ignition. I've now bought a kit with a piggy back fuse to wire it in more permanently. The problem I have is I still want it to turn off when I lock the car but so far I've had it connected to fuse 52 - front accessory socket, fuse 12 - reverse lamps plus one of the spares but even though the car has been locked for over 1/2 hour each time the camera remains on ? Can anyone tell me if any of the fuses in the glovebox are ignition controlled ?
TIA Phil
Post #469917 24th Feb 2018 5:45pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
you not got a multi metre pal ? just test each fuse ignition on then off Wink
Post #469926 24th Feb 2018 6:39pm
philip600
Hi, I have got a multimeter yes but as I understand it some circuits take a while to shut off after locking the car & ive already tried 3 circuits I would have though would be dead when the car is locked ? That & the fact that it's pretty difficult to connect a multimeter to a fuse, shut the door & then lock the car & then wait till it goes to sleep ?
Post #469932 24th Feb 2018 7:47pm
Rob99
On my 2012 Westie I have dashcam connected to F53 which is a spare with the right hand terminal live when ignition on. F54 is the same.
Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #469954 24th Feb 2018 10:43pm
philip600
Cheers for that, will try one of those 👍
Post #469955 24th Feb 2018 11:16pm
philip600
Rob99, thanks for your advice, fuse 53 & 54 both had 20amp fuses fitted on my 2012 Westminster although they are listed as spare in the owners manual ? Anyway I've used a piggyback fuse plugged into 53 & now have a dashcam that switches on & off with the ignition so happy days so thank you 😀
Post #470062 25th Feb 2018 8:40pm
Rob99
I guess yours must have some other option which needs the extra fuses.
Glad you've got it working though Thumbs Up Thumbs Up 2021 D350 Fifty Edition - Carpathian Grey
Post #470070 25th Feb 2018 8:56pm
