Home > Technical (L322) > Help on diesel leak |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Maybe it seals better once it warms up but just a guess |
19th Feb 2018 8:01am |
Johnsd1v8 Member Since: 06 Jul 2017 Location: Cheshire Posts: 190 |
I thought along those lines the pressure pushes the seal tight |
19th Feb 2018 8:47am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Have a read of This, it will tell you everything you need to know -
19th Feb 2018 10:41am |
19th Feb 2018 11:15am |
Cheers paul so it looks a fairly straight forward job |
19th Feb 2018 11:17am |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 145 |
Pay attention to this hose. Due to the heat and the time it crack and the diesel passes through it near the injection pump.
19th Feb 2018 11:56am |
The link wont open pal? |
19th Feb 2018 11:59am |
I never knew how to add photos here. Go to my gallery the image is there[/img] |
19th Feb 2018 12:02pm |
Yep i know the pipe you mean pal ive just done the jubilee clip on it where its goes on the pump i will check it further thanks where abouts did yours crack on the pipe itsself pump end yes |
19th Feb 2018 12:05pm |
Mine cracks near the pump. The clamp is a BMW one and is very strange to remove it. It must be done with a plier. Probably LR have a special tool for.
19th Feb 2018 12:11pm |
I know what you mean about the clip it was a fight to get that off and i did it in the dark so i didnt check the pipe but a picture of your cracked one would be a help thanks |
19th Feb 2018 12:24pm |
Any update on this one ? |
29th Mar 2018 4:43pm |
Well i havent toutched mine yet but it appears to have stopped leaking |
29th Mar 2018 4:56pm |
I think mine has done the same although i have stopped looking |
29th Mar 2018 5:43pm |
