Home > Technical (L322) > 2011 4.4 TDV8 - Restricted Performance
OtleyDominic
Hi All,
Help welcomed as I keep having the Restricted Performance message appear. It usually happens when the engine is warmed up and I stop for a few minutes / engine off, then when I start up the message appears. After it comes on, if I then stop/ restart , the message goes away for a good while. It seems intermittent but does not happen then the engine is cold.
The predominant codes related to water in the fuel filter, water in the fuel sensor circuit and EGR temp sensor A - circuit high.
The water in fuel filter seems to have been resolved by a new fuel filter housing.
It is booked into a specialist next week, but thought to check here anyways.
Post #469212 18th Feb 2018 8:00pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
seem to remember another member getting that message. Faulty sensor I think. Do a search Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #469230 18th Feb 2018 8:51pm
GraemeS
Australia
The faulty EGR sensor fault doesn't cause restricted performance on mine. I replaced the sensor because I spotted the fault code but the fault code soon returned so I ignore it.
Post #469241 18th Feb 2018 9:44pm
Would be looking for a boost leak somewhere. Possibly a split in one of the 4 shoe hoses to the plastic plenum or in the plastic intake plenum itself. There is nothing that can't be fixed with a hammer😜😜
Post #469260 18th Feb 2018 11:14pm
The first code is for a sensor in the NS exhaust manifold, this tells the ECU its running lean or rich this then increases or decreases the fuel trim... If it fails in one position then it will over fuel the car and it makes the exhaust STINK like a 1970s ice cream van!
This will fill the DPF prematurely and cause restricted performance issues too...
As stated above too, there is also a fair chance you have a split intake pipe... One of 4 linking the plastic inlet to the rocker covers Thumbs Up
Post #469268 19th Feb 2018 12:14am
OtleyDominic
Thank you, so it seems the EGR code would not cause the restricted performance. LR say it is bear being a ghost code. Would it be the water code setting it off then?
Post #469281 19th Feb 2018 8:41am
Banging Head Banging Head Banging Head Banging Head Banging Head Banging Head
Good luck with it sir....... Bow down
Post #469292 19th Feb 2018 10:16am
OtleyDominic
Thank you Craig
Post #469302 19th Feb 2018 11:25am
OtleyDominic
JAS York looked at it and fixed it for me today. It needed a new fuel filter housing and sensor, and a new exhaust gas temperature sensor.
Post #470441 28th Feb 2018 9:25pm
dirtymonkey38
Do you mind if I ask how much it cost for the repairs. I also have the same faults. Water in fuel circuit comes up every so often throwing the restricted performance warning (although it doesn't seem like performance is restricted). The EGR sensor is persistent though and i cant clear that with my IDTTool as it comes straight back on. 2011 RR Autobiography 4.4 TDV8
Post #471520 7th Mar 2018 6:40pm
OtleyDominic
I have sent you a pm dirtymonkey
Post #471558 7th Mar 2018 9:58pm
Baltic Blue
Otley Dominic,
Did you get the EGR sensor changed, and if so has it permanently cleared the fault code?
Post #471569 7th Mar 2018 10:28pm
dirtymonkey38
Received. Thanks for the info. Although not local, they are not a million miles away 2011 RR Autobiography 4.4 TDV8
Post #471576 7th Mar 2018 10:45pm
OtleyDominic
It takes me 1.5 hour drive to get there. But they have a loan car and a coffee shop nearby I worked from for the day while they had mine.
Post #471586 7th Mar 2018 11:26pm
nino_nino
Mike, can you post one of yours beautiful PDF's showing where the sensor is, I'll like to go at it. Very Happy
Nino,
Post #471604 8th Mar 2018 8:55am
